Guys, I need your help here...
In version 2.2 when I load a play list and drop the tracks on the decks I dont see them loaded.
I mean, I can't see the track in the bowser and when I press the "play" botton and nothing happens.
Was something changed or is it a real problem?
Cheers,
DJ Pazel
Cheers,
DJ Pazel
geposted Fri 03 Jan 03 @ 12:31 am
well, that'll happen if for one reason or another the file has changed location, or renamed since you made the playlist (m3u). The best thing you should do is re-scan the drive(s) and make a new play list. Or put all the files back exactly where they were, or re-name them back to what they were when the original playlist was made.
ADDED: after re-reading your question, I think perhaps you did not make and save an m3u playlist, but you had dragged files in from the search window. Be sure to re-scan the drive prior to a session if you are using the search window to select from. The search function does not refresh itself if file names are changed, or locations modified. Just re-scan the drive, and all will be fine.
geposted Fri 03 Jan 03 @ 1:45 am
Impressionsdj, what would i do without you :) ?
You're absolutely right, i've changed the location of some of the tracks.
I now created a new playlist and it worked !
Thanks and happy new year.
geposted Fri 03 Jan 03 @ 2:04 am
I would like to know if while mixing can I automatically creat or save the playlist of songs that I used?
geposted Thu 13 Feb 03 @ 4:57 pm
Enable "charts" in the options window. you'll then find the playlist in your atomix folder saved as "history" file.
greetz, patrick
greetz, patrick
geposted Sun 16 Feb 03 @ 6:59 pm
