Hi, I have on board sound,
Now I *heard* that if I get another soundcard, I would be able to use the headphones in the other soundport.
I could then have the speakers hooked up to the other sound,
and I could pre hear the tunes through my headphones, without them coming out the speakers until I corss fade.. I see ato supportts 2sounds, but doe sthis work?
thanks very much,
thanks very much,
geposted Thu 09 Jan 03 @ 7:44 pm
You will first need to purchase the software (atomixmp3).... sound confg. is not enabled in demo version.
You can use a single 3d sound card to have headphone support after buying the full version.
Any other help you need in hooking up ect....will gladly be offered but most will not go to the trouble until you become a full member..... (just too much trouble). The software is worth every penny you spend for it....and not that much to begin with. Hope this helps .... look forward to you becoming a full member of atomix.
Carman
Carman
geposted Thu 09 Jan 03 @ 8:05 pm
I see the price.. the demo is like 6 megs or so..
But like €65 for the piece of software.. :/
Bit out of my pocket since I'm a college student I'm afraid it will have to wait, thank you for your help
geposted Thu 09 Jan 03 @ 8:09 pm
the demo isnt 6megs the full version ia only around 4 megs
geposted Thu 09 Jan 03 @ 8:27 pm
I can't remember, I downloaded the demo ages ago..
when the plugins were free :p
bring them back for free! :p
geposted Thu 09 Jan 03 @ 8:49 pm
if we hold back the effects there is more incentive to buy it
geposted Thu 09 Jan 03 @ 10:23 pm
By the way, if you got the demo ages ago, then you'll be pleased to know that there is a new demo out now... it's version 2.2
geposted Fri 10 Jan 03 @ 12:59 am
I new v2.2 was out, didn't know there was a demo :D
geposted Fri 10 Jan 03 @ 1:20 am
