Hello,
I have a brand new P4, 3.0, 1gram,80ghd When I max the screen in VDJ then minimize the audio lapse for a few seconds and the screen goes black. Anyone have this problem?
geposted Mon 02 Feb 04 @ 3:23 am
Please, could you try a search before asking.
This is not a problem, this is because when you maximize, your screen resolution is changed to fit with the skin of VirtualDJ.
This is a display/graphic card issue. Not really a problem.
geposted Mon 02 Feb 04 @ 9:02 am
Ok, Any suggestions on how to correct it?
Thanks
Thanks
geposted Mon 02 Feb 04 @ 4:58 pm
well, one way would be to not min/max your VDJ display durring play back.
You might find it will be less of a problem if you set your windows screen res to 1024x768.
geposted Mon 02 Feb 04 @ 5:02 pm
Thank you for reply. I min/max because I use another Mixmeister pro for times I am not mixing. I will try the resolution change. ANy other suggestions are appreciated.
geposted Tue 03 Feb 04 @ 2:53 am
changing resolutions demands resources of your pc.
try not to change resolutions while doing a set, because it may have bad influence on your set. (audio hickups/clicks)
geposted Tue 03 Feb 04 @ 11:01 am
