I know....it's a thread i can find around...
But i have read stuff about y-splitters and to that effect and i am buffled...
Anyone that can provide info from scratch on how to setup up (cables) and perform (through ATOMIXMP3) being able to preview the track only with 1 soundcard...
i am thinking of buying the full version...it's worth every €!
Help will be greatly appreciated....
geposted Sat 18 Jan 03 @ 2:03 am
There is a link that can be provided to show you graphics on how to hook up the cables..... will be glad to provide after you become a member, by purchase of the software.
geposted Sat 18 Jan 03 @ 2:47 am
It's true, you can use either a Stereo splitter, or a USB sound device as a 2nd sound card to enable you to preview the next song, while one is playing. However these important sound configuration options are NOT available in the demo version. To use these features, you must purchase the full version of Atomixmp3.
(remember, that will also give you full access to all of the effects plug-ins. For $59.95, it's a bargain.)
geposted Tue 21 Jan 03 @ 12:43 am
I have the same problem with previewing tracks with 1 soundcard. Any help and the above mentioned link is appreciated. i am a licensed user of AtomixMp3. Thanks!!
geposted Tue 21 Jan 03 @ 6:01 am
Hi DJ Home Boy,
Please tell me how i can possible preview a sond when i only got one sound card.
Thanks for helping
Thanks for helping
geposted Fri 14 Feb 03 @ 10:12 pm
I have used a creative 5.1 Soundcard and Managed to Play on output A and preview on output B (set soundcard for 4 channel) I wasn't happy with the quality and prever the old 2 channel creative labs card.
If you have AMD cpu, then you got onboardsound and you onley need one extra soundcard.
Good luck
Good luck
geposted Sun 23 Feb 03 @ 9:48 pm
