I already have a numark console that i bought which has PCDJ. is there any way to download a trial version or just bying the software of atomixmp3 pro?
geposted Thu 23 Jan 03 @ 2:39 am
Nope. The controller you have is ONLY meant for the software it was bundled with.
geposted Thu 23 Jan 03 @ 4:43 am
thanks, so in other words the numark consol that I bought is useless, cause the program that came with it doesnt have half the functions atomixmp3 does. By the way, is atomixmp3 pro exactly as the normal demo version? Cause I've only got the demo of atomixmp3 and its brilliant, and i was wondering that instead of bying atomixmp3, i could instead buy atomixmp3 pro if it was compatible with the console I got. But thanks anyway.
geposted Fri 24 Jan 03 @ 1:32 am
Just buy Atomixmp3, and a nice wireless mouse. You don't need the controller!
geposted Fri 24 Jan 03 @ 8:08 am
