Beleza galera? Gostaria de saber como fazer um download de um Effect Plug-ins. Eu já fiz meu cadastro e tudo, mas não sei como fazer o download. Espero que me ajude.
Obrigado!
Obrigado!
geposted Sat 08 Feb 03 @ 4:00 am
Hi!
You can't download effects becauese you are a demo user.
You have to buy the full version if you want new effects.
Peroz
Peroz
geposted Sat 08 Feb 03 @ 9:23 pm
i have the full version .i download several effects but i unable to have it on the program when i run it.wat shall i do?i dxt even see the folders
geposted Mon 10 Feb 03 @ 1:01 pm
Have you placed your downloaded plugins into the "plugin" directory of Atomix ? If you did, just select the plugin in the soft by changing one of the three plugins affectation with the new one...
If it doesn't appear, maybe you'd better check if you're not copying your plugins in the dir of an old demo version... I did it in the past...
Slash
Slash
geposted Mon 10 Feb 03 @ 4:17 pm
