Forum: Old versions
Topic: AUDIGY 2 SOUNDCARD
I am thinking of buying a creative labs soundblaster audigy 2 soundcard to use with VirtualDJ. Is there anyone out there who uses this soundcard? If so any comments, good or bad would be appreciated. Cheers!
geposted Fri 06 Feb 04 @ 2:23 pm
Audigy 2 soundcard has the same, or worse quality then this Hercules DJ console.
Better would be to use the Audigy 2 Platinium Pro, if you wanna go for quality
