I download the skin to my 'more skins' file, unzip it, and extract it to my more skins file, then i copy and paste it to my regular skins file....all good right? wrong...when i start up atomix and try to load my new skin it immediatley shuts off...i see the new skin for like a blink of the eye, then it shuts off.....help
geposted Tue 18 Feb 03 @ 3:31 pm
Which demo version are you using?
geposted Tue 18 Feb 03 @ 3:35 pm
im using the full version
geposted Tue 18 Feb 03 @ 10:54 pm
So please update your profile and register it with your serial number
geposted Tue 18 Feb 03 @ 11:39 pm
Tell me, HOW DO I CHANGE MY SKIN? It only mankes sence that the best underground DJ have the best skin. Sincerly, DJ RasKel
geposted Fri 21 Mar 03 @ 9:47 pm
nauticanaz, look here : http://www.atomixmp3.com/forum/display.html?topic=9064
geposted Fri 21 Mar 03 @ 9:58 pm
how do i become a v.I.p member?
geposted Fri 21 Mar 03 @ 11:22 pm
to begin with... you must buy the program... seems like the best underground dj wouldn't be working with a demo..
then be helpfull to others in the forum. That's how to get your level increased.
geposted Fri 21 Mar 03 @ 11:23 pm
cant load skin, done all the above still cant load it ,,whats going on!
what are the steps in order to do this please.....
thanks
thanks
geposted Fri 28 Mar 03 @ 12:48 am
Download from this site the last demo version and reinstall atomixmp3. Then try again to insert your two skin files (xxx.xml and xxx.bmp) inside the skins folder in atomixmp3 's dyrectory.
Peroz
Peroz
geposted Fri 28 Mar 03 @ 12:54 pm
