I've got a problem while changing the sound of a song when using VDJ. It seems to me that when i get the bass up, the mediums go down. And when i push the mediums up, the bass go down. I use vdj with the DJ console.
Do someone experienced the same thing ?
Thanks
Loic
Thanks
Loic
geposted Fri 06 Feb 04 @ 7:51 pm
I don't have such a problem but, if you have the limiter option ON, I imagine this "might" occure.(not sure)
explanation:
If your song level is high and you push the gain of the bass, the limiter will lower the level song so
-> You push the bass but the others frequencies will be reduced due to the limiter (the average level of the song).
I did try this, maybe it is what happen to you. Try to disable the limiter in the options.
Give us a feedback to help others users that could have the same behavier.
Good Mix
explanation:
Good Mix
geposted Fri 06 Feb 04 @ 9:19 pm
