i was recording the other day and i was doing alot of cutting.. quickly from Deck A to Deck B-- and then back to A--- in between beats... what happens is that the recording can't keep up with the quick cuts ( i think) and creates another track everytime i go from deck to deck... Is there any way to get rid of that so i can make the full recording...i mean it sounds great live but when i hear it recorded there is pause for about 1 second then and it looks like i messed up the mix.....
thanks
thanks
geposted Thu 20 Feb 03 @ 7:06 am
Disable Auto-Cut.... Problem solved.
(But what would be great is a Cut-shortcut.)
- Jim Nordic
- Jim Nordic
geposted Thu 20 Feb 03 @ 7:37 am
i dont see that name as an option... are you talking about the crossfader? because i have that at full....
geposted Fri 21 Feb 03 @ 1:57 am
No. If I understand your problem correctly, my suggestion is that you disable the Auto-cut-feature in the Recording-window.
This will make Atomixmp3 make a full recording without cutting it into tracks when using the crossfader.
- Jim Nordic
- Jim Nordic
geposted Fri 21 Feb 03 @ 3:35 am
