Just got M-Audio's new USB multi-channel soundcard (similar to the SB Extigy) and I was trying set this up for monitoring through headphones...
Anyone know the configuration for this, or if it's even possible? I hope so, as it would be a great solution for laptop users (24/96 output, bus-powered, $120).
geposted Thu 20 Feb 03 @ 7:17 pm
If your USB soundcard has 2 or more outputs you can use it with atomixmp3 for monitoring. You have to go to the sound setting menu of atomix and choose 3d soundcard and headphones + speakers. Then you have tu put the headphones jack and the speakers jach in each of your two outputs of your soundcard.
Peroz
Peroz
geposted Sun 23 Feb 03 @ 4:46 pm
