I've got a tag editor and the comment field is not showing up in vdj am I doing something wrong?
geposted Sat 07 Feb 04 @ 7:46 am
No, the comment in VDJ don't come from Tag but from VDJ internal database.
You have to write comments in VDJ if you want to find them next time in VDJ.
Other solution: to see your id3 comments in VDJ, you have to use the ID3 parser plug_in and use the option that put the comment in the same column than the autor name.
I guess this help you.
Kaleo.
Kaleo.
geposted Sat 07 Feb 04 @ 11:02 am
Thanks
but the id3 tag phraser crashes VDJ, I don't want to install it anytime soon. Is there a way to directly edit the internal database?
geposted Sat 07 Feb 04 @ 11:52 pm
