ok, i went to the download and downloaded the file. I unzipped it and put it in my skins folder... but when i click on the skin to change it. there are no skins except the default skin. Can anyone help? I may have done something incorrectly.. thanks
geposted Sun 23 Feb 03 @ 12:46 am
when you say you unzipped it... do you mean that you unzipped both an XML & BMP file to your Atomixmp3 skins directory?? If you did, it should work.
geposted Sun 23 Feb 03 @ 2:55 am
