Forum: Old versions
Topic: sound card settings not 'sticking'
I have the full version of atomix, and am running it on a computer with built in Nforce2 sound and an Audigy 1. No matter what settings I use (Atomix will let me choose Nforce controller, Audigy Audio, or Primary Sound Driver), I will only get output out of both decks on my headphones (plugged into Nforce) or my speakers (plugged into Audigy). I can't get A to play on speakers and B to play on headphones. When I go back to change the settings, I notice that it always reverted back to single card and speakers even after I had changed it to two sound cards and headphones/speakers. Is it supposed to do this?
I have also tried using my Audigy as a 3d card with the headphones plugged into rear. In the audigy control panel, I can hear the front through the speakers and the rear through the headphones, but again when I use Atomix, the sound from both decks will only play through headphones or speakers, not both. Again, the settings don't 'stick' when I change them.
Any help? Ideas? Thanks a lot.
geposted Wed 05 Mar 03 @ 11:55 pm
update your profile with your serial then you are more likely to get help!
