When I record, I like to enable auto-cut, mainly because its convient if i burn the mix to CDR to give the user the ability to jump to a certain track. On the other hand, I would like to have the mix as one file (like disabling auto cut), so that I can convert that 1 big .wav file into an .mp3 file for download/upload distribution over the net.
My question is, after I have recorded the mix, using auto cut, is there any way, either through AtomixMP3 or another app, that would let me take all those cut files (lets say 20) and put them into one continuos file for the conversion (like when auto cut is turned off) ... or do I have to make 2 mixes, 1 with auto cut, and 1 without? Thanks all.
geposted Thu 06 Mar 03 @ 7:55 pm
yes
geposted Thu 06 Mar 03 @ 10:28 pm
yes to what ... you have to make seperate mixes?
geposted Thu 06 Mar 03 @ 10:41 pm
If you record your mix in one shot, you can separate them with another software like nero burning rom
Norm
Norm
geposted Thu 06 Mar 03 @ 10:55 pm
cool, thx ... is there a way to set auto cut to disabled by default ...
geposted Fri 07 Mar 03 @ 12:26 am
