Hi Peeps,
I dont know much about Mono and Stereo splitters, so i thought i would just ask cause i am thinking of purchasing 1.
What is the difference between a Mono and a Stereo splitter? If anybody can provide an explanation, i would be most grateful.
Cheers..
Dark Storm
Cheers..
Dark Storm
geposted Sun 16 Mar 03 @ 8:50 pm
well this option is only available in the full version!
geposted Sun 16 Mar 03 @ 10:12 pm
..but just to shed a little light on the subject, there are basically 2 types of stereo/mono-splitters:
either the splitter sends a mono-version of the input to both outputs which basically give you two identical mono-channels, that's the kind you don't want for Atomix, the other type of splitter separates the left/right channel from the stereo-input and sends left to one output and right to the other... that's the kind of splitter that works with Atomix (and other programs that use left-right stereo separation to give you two different mono-channels from one stereo output).
geposted Mon 17 Mar 03 @ 3:11 pm
