this another good trick for thos people that use all the keyboard have to try...
for an example go to the short cu config and
add a new key whith a 1/8 loop , then another key with Eq reset.. wen you do the loop thing (you know start with a long loop and finish with a shor)you can finishd with a easy way and you don have to worrie if you miss the key ...you jus only have to do is press one key to finish and at the same time you can reset your eq if you had changed the Eq frec
the piont is that you can use in only one key more than one shortcut and that means more posibilities...
Dj nash
Dj nash
geposted Mon 17 Mar 03 @ 10:41 pm
