I need to buy a soundcard. I have the option of using the onboard sound on a pc-cube or upgrade to a soundblaster series card. The soundblaster live 5.1 is the cheapest, but the soundblaster audigy 2 is next up. Does anyone use any of these cards and or can anyone point me in the right direction. Thanks.
geposted Wed 11 Feb 04 @ 9:30 am
Hi,
I use the USB Externe Creative Audigy 2 NX sound card with VDJ.
Please, find more information on the following link :
http://www.creative.com/products/product.asp?prodid=9103
Regards
Laurent
Regards
Laurent
geposted Wed 11 Feb 04 @ 10:44 am
Hi!
I can say to you, Use de Numark DMX01 USB and you have the mixer and the sound card integrated
Look this
https://virtualdj.com/forum/display.html?topic=3595
Look this
geposted Wed 11 Feb 04 @ 2:27 pm
Soundblaster is ok for home-use.
if you need a fine soundsource in front of a live audience, you'd better buy a more professional card like M-audio Delta 410 or Maya EX.
geposted Wed 11 Feb 04 @ 3:29 pm
use the XP-10 !!
geposted Wed 11 Feb 04 @ 4:03 pm
