i'm using demo
I simply connected my external mixer (JBsystems) to my 2 soundcards (2 x 3D cmedia) , all setup is well ... but
my left channel (atomix) plays much louder than my right one
the left is like I would set the gain to maximum (which i didnt do... setup on my mixer (and in atomix) from left/right channel is exactly the same...
so where is the problem? I already tried reïnstalling both my soundcards. I don't suppose it will be necessairy to reinstall my atomix? would it?
plz help me, I would be very greatfull
and thx in advance
gib
and thx in advance
gib
geposted Fri 28 Mar 03 @ 2:41 pm
You need the full version...
geposted Fri 28 Mar 03 @ 2:44 pm
You can't split the output to 2 seperate devices using the demo.
geposted Fri 28 Mar 03 @ 3:43 pm
bullshit
last time it worked perfect with the demo
now it doens't so it has something to do with soundcard configration
any help is welcome
any help is welcome
geposted Fri 28 Mar 03 @ 5:44 pm
you ask for help and 2 users (both high ranking) help you and you say "bullshit" so i doubt anyone else will help!
geposted Fri 28 Mar 03 @ 7:17 pm
You can not have seperate outputs configured using the demo version!!
Plain and simple!
Seems that you apparently already have all the answers tho, so why did you ask?
Plain and simple!
geposted Fri 28 Mar 03 @ 8:35 pm
Perhaps you are not using the demo. But if you are there are no soundcard configuration abilities....
geposted Fri 28 Mar 03 @ 8:56 pm
