Went to RS yesterday and bought me a Y-Adapter to preview songs.
reyzilla
reyzilla
geposted Fri 04 Apr 03 @ 7:18 pm
You must have the original full version
geposted Fri 04 Apr 03 @ 7:24 pm
Before a post like that can stand, you need to go to the forum log in and update your profile so that you show up as a full version user.
Sorry for any confusion.
geposted Fri 04 Apr 03 @ 7:35 pm
What version lets you use the Preview?
geposted Fri 04 Apr 03 @ 7:37 pm
Only the full purchased version of Atomixmp3 allows for split output configuration. This has been a demo limitation since the very beginning of Atomixmp3.
All versions have had this same limitation in the demo.
geposted Fri 04 Apr 03 @ 7:41 pm
It's a matter of perception... sound configuration tips and hints coming from someone showing up as a demo user may be percieved by other users as possible without buying the product. You should update your profile, and then restart this thread...
geposted Fri 04 Apr 03 @ 7:43 pm
