How come some wav files fail to open in Atomixmp3? I have no problem opening these in Windows media player. The bit rate is 32kbps and the files are of 1 to 3 minute in length. When I drag the file to one of the decks I get the message - impossible to open the file. When I try to convert the file to an mp3 I get an error. Is there anything I can do to get such files working? It is not all wavs but aproximately 20% that I download from the net? Any help much appreciated.
geposted Wed 09 Apr 03 @ 6:26 pm
are they in 44.100 ? So, convert them
geposted Wed 09 Apr 03 @ 7:14 pm
Hi :)
Firs of all i suggest u to transform all your wavs to the MP3 format (only if you have to listen to them or to mix them; is not good if you have to work or manipulate them).
If you get some error in the transformation process (wav->mp3) you could try to change the transformation program.
Good luck
Peroz
Good luck
Peroz
geposted Thu 10 Apr 03 @ 7:17 pm
Thanks guys
geposted Fri 11 Apr 03 @ 3:00 pm
