does atomix support joysticks?
What I mean is if I have a game controller or joystick with 6 or 7 fire buttons will the atomixmp3 program recognise these buttons as a shortcut?
Thanks
Steve
Thanks
Steve
geposted Fri 11 Apr 03 @ 1:04 am
I think it only recognizes the movement of the stick left to right for crossfader.
geposted Fri 11 Apr 03 @ 9:46 am
I have a few designs for controllers that use 4-way switches (like a joystick) plus buttons to control the major functions of atomix. You can get custom sticks that end in a pigtail...which means you can connect it to a keyboard circuit..... ;)
Regards,
Diaggbyte
Regards,
Diaggbyte
geposted Fri 11 Apr 03 @ 11:52 am
got no cd Jukesy.......at work no time!
geposted Sat 12 Apr 03 @ 2:34 pm
