Hi,
I'd like to know if any of you guys use the volume control on the atomixmp3 mixer or do you only play with the crossfader with volume max up.
Scenario: If you have the crossfader at 80% towards deck A (full crossfader setting), is it the same as having the volume on deck A at 80% and deck B at 20% volume capacity with the crossfader at middle (full crossfader setting).
Is the equalizer react the same on the output either way
Thanks,
Djnoma1
Thanks,
Djnoma1
geposted Sun 13 Apr 03 @ 7:44 pm
Yes, I think its the same... I already used both ways with the full crossfader setting and the volume sounds equal... But I personally prefer the crossfader to control de volume, because in the other style (controlling the volume with the bars) requires the use of 2 shortcuts and that requires more effort and dont let you much freedoom to play with other things... but well, is your choice : )
geposted Fri 18 Apr 03 @ 9:02 pm
