I am a proud owner of a DJ Console and I am thinking of purchasing the FULL version. I have noticed that you may use a midi keyboard with the full version. Im just a bit stumped on how this would work and what the advantages of this would be. Would you be able to play live while mixing? Any other software required?
geposted Fri 13 Feb 04 @ 6:17 pm
No, midi support on VDJ is for Midi controler, not to play.
If you have a Midi keyboard (for exemple), the keys could be used as shortcuts.
geposted Fri 13 Feb 04 @ 8:51 pm
