Greetings from Wales, UK.
I have an AMD K6 (200mhz)
Windows 95, 64ram
Slow.. yes!
My mp3s plays fine on winmx, but on programs like
atomix, the sound is slow and "wobbly!".
Anybody know how I could improve the sound, by downloading something, like codecs?
Windows 95, 64ram
Slow.. yes!
geposted Thu 24 Apr 03 @ 12:43 pm
No codecs. And yes, your PC is pretty slow. Other have been successful using Atomix on slower then recommended PCs by turning off all the extra features and running it in hardware mode. Not sure if that will help you much though since you'r running on a K6 200. Thats like running on a Pentium 1 @ 166MHz. And the ammount of memory you have isn't great either. I'd say its time for an upgrade.
Grimm
Grimm
geposted Thu 24 Apr 03 @ 7:21 pm
Yea man, Grimm is right!
Your PC is old :(
You can try to defrag your HD and update video and audiocard drivers.
Good luck
Peroz
Your PC is old :(
Good luck
Peroz
geposted Fri 25 Apr 03 @ 1:04 pm
also try to analyse ech song good luck i know what it is run atomix on a slow machine its very frustrating just have paciense
geposted Sun 27 Apr 03 @ 8:23 am
