sorry guys this aint about atomix.
I just want to know which is better quality and what are the advantages of.avi (dix) extension files or .mpg extensions.
Cheers
Jukes
Cheers
Jukes
geposted Sun 27 Apr 03 @ 11:03 pm
While MPEG uses only a main frame of reference and calculates the next for differences, an avi clip calculates each frame individually, and its total dimension is given by the dimension of a frame for fps (the number of frame per second) and for the duration total of the clip in seconds. It's easy to deduce, therefore, that this will have a weight greater than MPEG, but also a better resolution. For an exaustive list of compression formats for the visualization of clips/videos visit www.omeganet.it/utenti/indiana/formati video.html.
[Italian]!!
[Italian]!!
geposted Wed 30 Apr 03 @ 9:16 am
Thanks.
Jukesy
Jukesy
geposted Wed 30 Apr 03 @ 3:52 pm
I have used both mpeg 4 and divx to encode video and if your looking for high compresion and great quality go with divx. Just gotta know how to set it up right thats all.
geposted Wed 30 Apr 03 @ 7:44 pm
