Does anyone know how to download the effects?
Whether I save it or Open it, I keep getting some Russian writings on a note pad.
geposted Thu 01 May 03 @ 11:37 am
IM Still waiting {Patiently}
Anyone?
Anyone?
geposted Fri 02 May 03 @ 11:26 am
save it in your effects folder in the root folder of Atomix.
geposted Fri 02 May 03 @ 11:31 am
disable any type of download accelerating software you have installed. Clear the browser cache, right click the file and save target as ...
geposted Fri 02 May 03 @ 4:16 pm
OK, I'll try the second one.
I don't have any software like you described but I do use Cable “I don't know if that's relevant”.
geposted Sat 03 May 03 @ 12:35 pm
No! Guys there are no use.
Even when I execute it on my desktop it runs like a note pad and no new effects in Atomix.
Any other suggestions?
P.s I did do everything you told me, clearing my web caching and right clicking to Save As…
geposted Sat 03 May 03 @ 1:15 pm
You can't "open" an effect. You have to save it to the atomixmp3 evvects folder, then access it with the effects page of Atomixmp3.
geposted Sat 03 May 03 @ 3:43 pm
you should get (download) a .dll file and then save it in the effects folder
geposted Sat 03 May 03 @ 9:33 pm
OK, OK, I understand now.... (I hope)
geposted Sun 04 May 03 @ 1:22 pm
Yeah I got it, thanks to you two.
geposted Mon 05 May 03 @ 2:06 pm
Great !
geposted Mon 05 May 03 @ 5:23 pm
