Hey guys,
I was thinking...is there a way that someone can skin atomixmp3 to have 4 audio signals like four active desks and two mixing channels w/ assignment...Tell me your thoughts
geposted Fri 09 May 03 @ 3:17 pm
That's not possible. The only way is launching 2 atomix sessions.
geposted Fri 09 May 03 @ 3:23 pm
well having two open programs is hard to do without the right size monitor? Take this into consideration when making the next version.Some DJ's like would like to mix with more than 2 sources...DON'T YOU AGREE?
geposted Fri 09 May 03 @ 9:06 pm
it has been suggested, but nothing happend.
But if you can run multiple instances without any problems. Why can't you make it into one programme?
geposted Sat 10 May 03 @ 5:26 pm
