I'm thinking to buy the program but first I need to ask some things. I'll be using the program with 2 Creative live 128 soundcards. Is it posible to configure my PC to do so. I tried to but then the other music programs that I use ( Musicmatch Juke Box) dont work at all. Is there a way to make sure that thinks will work well before I buy the product? Thanks in Advance!
geposted Thu 12 Jun 03 @ 7:21 pm
Sir,
You should have no problems configuring that card with AtomixMp3.
geposted Thu 12 Jun 03 @ 7:52 pm
Sorry to bother again, but will the rest of the music software on my PC work OK? I've placed the 2 sound cards in my PC to see what it hapens and the system seems to got in a mess. THE REST OF THE MUSIC SOFTWARE, not Atomixmp3 which I guess will work since it's ment to do so, doesn't work.
In conclusion will both atomixmp3 an other music software work OK?
Thanks Again! :-)
Thanks Again! :-)
geposted Thu 12 Jun 03 @ 8:56 pm
