Hey,
who knows a good trick to keep a track with a variable BPM together with another track?
I want to mix this great techno track but it has a variable BPM.
So what should I do???? And please don't answer with "pick another track" cos I really want to mix this one properly and smooth.
GnoedeL
GnoedeL
geposted Sat 14 Jun 03 @ 7:40 pm
Try using the nudge shortcuts to keep it in sync or record it in pieces and then beat mix it together...
geposted Tue 17 Jun 03 @ 9:34 am
figure out the BPM of the portion of the track where you want to make the mix, and find a song that matches up well with that section....
geposted Fri 20 Jun 03 @ 12:30 am
Maybe I should try the Manual BPM tap, it should work.
geposted Fri 20 Jun 03 @ 10:13 pm
I am a atomix user since version 1.2 and now i'm using version 2.2..... and i have no trouble with any song that i was play althuogh it has variable bpm. I was disable all auto features, and using manual way to beat match and anything.And it more easy than using automix or magic.... more accurate and don't forget to reset keyboard shortcut.... and using nudge to match ......
geposted Sun 21 Sep 03 @ 9:09 pm
just trust your ears and nudge it using also the small + and - for the bpm slider.In freaking moments use magik.:)
good luck
good luck
geposted Sun 21 Sep 03 @ 9:33 pm
hi there i am marco from south africa :)
please tell me
where do i download atomix2.2
i have 2.1
please tell me
i have 2.1
geposted Wed 17 Mar 04 @ 10:23 pm
marcostassen,
You can download here: http://www.atomixmp3.com/download.html
geposted Wed 17 Mar 04 @ 11:10 pm
2.2 is no longer available. Download 2.3
geposted Wed 17 Mar 04 @ 11:23 pm
how do i get to hear a beat of a song alone and i want to hear it good too
geposted Fri 18 Jun 04 @ 8:42 pm
The manual BPM TAP works good for me.It never fails once yu know at what point to cue your song.
geposted Sun 27 Feb 05 @ 7:42 pm
I WANT TO DO MIX AND HOW DO I HAVE TO DO IF I WANT TO USE TWO ATOMIX
geposted Sun 08 May 05 @ 12:28 am
HEY YO IS SOMEBODY THERE ?
WHEN ARE YOU GONNA GIVE TO ME THE ANSWER??
SORRY IM NEW BEING HERE NO MIXIN`
geposted Sun 08 May 05 @ 12:30 am
O.K. IM LEAVIN` NOW SEE YOU LATER¿
JUST TO SAY SOMETHING
geposted Sun 08 May 05 @ 12:34 am
whats does the visual-effect do
geposted Fri 24 Jun 05 @ 11:35 pm
