New user here. How can I engage the Automix feature to automix my playlist? I've loaded the songs into my playlist and turned on the star button, but when one song finishes, I can see the next song load, but can't hear it play. Any help?
geposted Tue 24 Jun 03 @ 5:13 pm
have you got the sound config setup correctly?
geposted Tue 24 Jun 03 @ 7:47 pm
How does the sound need to be configured?
geposted Wed 25 Jun 03 @ 6:53 am
Are you sure the song you want to play, are always in the same folder when you are made a playlist?
That’s very important, if you move your files and you don’t make a new scan, atomix see the song in the playlist, but can’t find it.
geposted Wed 25 Jun 03 @ 8:03 am
check your volume controls.....lol...just joking.....if you find a fix let us know....
geposted Wed 25 Jun 03 @ 11:39 am
sound config depends on what your using!
tell me what you using
geposted Wed 25 Jun 03 @ 7:13 pm
