In the 'infos' panel how come some MP3's will display just 'Spent', 'Left' and 'BPM'. Whereas some others show these plus 'Cue' 'End' 'Pitch' and 'Volume'. I want them all to display this info but I dont know how.
geposted Thu 26 Jun 03 @ 5:33 pm
Just edit the XML file of the skin and add what values you want.
geposted Thu 26 Jun 03 @ 5:35 pm
Can someone please tell me how to edit the default skin so it displays all of the info listed above. I'm not very good with the XML file. Thanks
geposted Thu 26 Jun 03 @ 5:44 pm
try going to the skins area of this site and downloading some skins. the one i find the best is the Bassik LE BLU....and there are many more out there with many more toys and such....
good luck in hunting skins...for atomix that is.....lol
geposted Fri 27 Jun 03 @ 6:29 am
You can edit the xml file using note pad too (but remember to save the file as .xml then)
geposted Fri 27 Jun 03 @ 4:12 pm
