Forum: Wishes and new features
Topic: MORE SAMPLES
I use a lot of sound clips in my shows, many of them more than once...too much trouble to play them in the main program and then I can only play them ONCE unless I restart the prog...seems like it wouldn't be that hard to allow more samples in the sample section of the program...like 20 or so?
geposted Mon 07 Jul 03 @ 5:00 pm
HOW DO I GET NEW SAMPLES
CAN I DOWNLOAD MRE SAMPLES
FOR PATIES
CAN I DOWNLOAD MORE SANOLES I NEED IT FOR A PARTY
Make a research with google, just type : sample, and enjoy
PS: please don't shout, unlock your caps !!
Someone can give me in the request of direct affiliation [direct affiliation request] that I will be able to lower will be put sample and effect please i new In the occupation
Hey on "your" computer go to "my computer" than go to your "c:" drive where u installed Atomixmp3 and click on the folder than go to the "samples" folder and inside you'll see all 12 samples that came with Atomix and a "internet shortcut" to a website where you can download "MORE SAMPLES" :)
tone-a is right. But you can use any sound as a sample as long as its the right format i have about 200 samples
Lou thats cool i never knew you can load a song in the samples, thats like adding more decks expect you have to fade away the track with the volume slider and also you can't use any effects but i still think its good that you can use a sample slot for an extra deck or decks.
Yes Tone A as long as its in wav or mp3 format you can load them in the samples :)
i was on a1 sounds the free sound are free you have to right click and click save target as
