My atomix was working fine, but one day I was playing around with the sound config, to try to fix this:
http://www.atomixmp3.com/forum/display.html?topic=11318
and simce it skips when I grab a song to move its position in the song, despite me putting it back to its original settings.
The display of the songs is 'slow', seems to try to catch up on itself constantly. I haev tried to reinstall but it makes no diference.
Anyonew know what that is, or how to fix it?
Thanks.
Thanks.
geposted Sun 13 Jul 03 @ 5:53 pm
uninstall atomix...then do a defrag on your computer..reboot and install atomix and reboot again...i would try that...i don`t know if it will work but its worth a shot
geposted Sun 13 Jul 03 @ 9:59 pm
if the problem is what i think it is its because the cd your playing has scraches or the sound file has a flaw
geposted Mon 04 Aug 03 @ 6:46 pm
