Forum: VirtualDJ Skins
Topic: Help finding Tool
I'm looking for a tool to transform a rectangel to a "half-circle".
I would like to make something similar to the pitch-bar on the default-skin from a vertical bar.
I've tried to find it paint shop pro 7... but no luck.
Thanks for your reply.
-Jim
geposted Wed 23 Jul 03 @ 3:14 pm
Have you tried corel draw or corel paint ?
I tried coral draw many years ago. Powerful tool.
I would like to try adobe Illustrator aswell.
Do you know if that is the SW chosen to make the default skins?
Thanks...
- Jim
