Forum: Old versions
Topic: Freezes while playing song w/SB 5.1 3D
NY-DjHome userMember since 2003
Hi,
Using Home PC with amd 2000, win XP, 80 GIG, 512 DDR ram. Couldnot get it to sound right with the onboard sound card and a SB live 5.1
Got the que working with speakers and headphones. SB is set on 3D. But I get a load noise and a freeze up every now and then for a second while playing a song and also during a mix. Can anyone help me fix this problem?
Thanks
Andy
geposted Tue 12 Aug 03 @ 2:10 am
In atomixmp3 setting, set your configuration for: 3D card / headphone, choose your SB 5.1, disable 3D option. In windows: In control panel set at quad speakers.
In SB 5.1, connect your headphone in the green output and the speakers in the black one.
In soundcard control panel, close all input you don’t need (line-in, mike.. maybe the noise came from another application) By default, atomixmp3 up your volume at max.
Try this :-)
Coyote
geposted Tue 12 Aug 03 @ 3:04 am
Thanks Coyote,
That seems to do it. I had to put the haedphone into the green and the speakers into the black.
Thanks again
Andy
geposted Tue 12 Aug 03 @ 4:15 am
