Forum: Old versions
Topic: INTERNAL DATABASE CORRUPTED
Hi There
I have just installed some KODAK software for my new digital camera and I now cannot open Atomix, I get the above message.
What procedure do I follow to re-download Atomix.
Many Thanks
geposted Wed 13 Aug 03 @ 8:33 am
Email to : service@atomixmp3.com
Coyote
geposted Wed 13 Aug 03 @ 8:39 am
HomeboyPRO InfinitySupport ManagerMember since 2003
It is not required to re install simply remove the internal db from the root folder of Atomix.
geposted Wed 13 Aug 03 @ 8:57 pm
Unfortunately, you aren't able to fixed the corrupted file :( Delete it, that's the only way.
Of course, save it often ;)
geposted Sun 17 Aug 03 @ 1:57 pm
same here its a pain in the bum..all the work i done and it says INTERNAL DATABASE CORRUPTED what i now do is back up the file on 3 1/2 disk
geposted Tue 02 Sep 03 @ 6:15 pm
