I want to buy the pro version of Virtual Dj,
but i want to use my own mixer...
I searched for some soundcards which have two or more outputs.
I found the AUDIOTRAK MAYA EX USB
and the AUDIOTRAK MAYA 44 USB....
Can I use both to play two different MP3 songs on two differnet RCA Jack outputs or do i need to buy the audiotrak maya 44 with ASIO drivers???
Does anyone know a better solution???
greetz hans
greetz hans
geposted Tue 24 Feb 04 @ 11:59 am
You want to buy a "Pro" or a "Full" version ?
Because in a "Pro" version (EKS XP10 controller) you have a pro sound card include onboard
geposted Tue 24 Feb 04 @ 6:11 pm
TERRATEC PHASE 26 & 28 are very good. I think VDJ does not support ASiO drivers.
geposted Tue 24 Feb 04 @ 7:13 pm
I want to Buy the "Full" Version of VDJ not the "PRO" Version. Does anybody know if VDJ works with the AUDIOTRAK MAYA 44 USB or the AUDIOTRAK MAYA EX....
I read several times that the Terratec products should be very good, but I can't find teh Phase 26 or 28...
Are these older Products????
Or can you buy them only in some parts of the World...
thanx
Hans
thanx
Hans
geposted Thu 26 Feb 04 @ 5:26 pm
Ok now I found the Phase models....
These are good Cards, but the don't have what I want.
I want a Card that has 4 RCA Jack Outputs (2 Channels)!!!!!!!
The Card should be USB and work with VDJ!
geposted Thu 26 Feb 04 @ 5:31 pm
The Phase 26 is USB, needs NO drivers (WDM) and has up to 8 RCA Connectors (back of the card). A virtualDJ user owns it I don't remember his nick name, and it seems to work properly with VDJ (even two outputs).
The resolution of the card is 24bit/96KHz.
FRUiT94
FRUiT94
geposted Thu 26 Feb 04 @ 6:15 pm
thanks allot...
geposted Fri 27 Feb 04 @ 9:52 am
Hello,
I use the USB SoundBlaster Audigy 2 NX.
Please find more information at the below URL link :
http://www.creative.com/products/product.asp?prodid=9103
Regards
Laurent
Regards
Laurent
geposted Fri 27 Feb 04 @ 10:35 am
I use the Creative Audigy 2 NX too. It is a pretty good sound card but there's no RCA connections.
geposted Fri 27 Feb 04 @ 10:38 am
