i'm trying to save and then print a playlist of the mix i've created. i've clicked history and saved it-.i've loaded tracks on the right hand side column ready to mix-then click automatic mixing.tracks mix,stop recording,then check history but all i've saved is the date??help!please guide me thru,step by step.what am i doing wrong?i just assumed that whatever tracks were mixed would show on the history.guide me through it please!thanks.i've searched through previous questions about this but found the instructions a bit sketchy.easy guide please!
geposted Tue 16 Sep 03 @ 2:08 pm
Try looking in C:\Program Files\AtomixMP3 for the file history.txt and open it with any text editor (Word, notepad ect.) look for it after you close Atomixmp3. Hope it helps
geposted Mon 22 Sep 03 @ 4:55 am
