I want to use the automix feature at a party. I have a folder of mp3s the software has never played before.
I found this message below...
________________________________________________
If atomix has never played the song beeing played before, it will start to mix at 80% of the song.
And, if the song has already been played once, it will start the mix so that the mix will finished on the last beat of the song.
I'll try to correct that in the next version. But the solution for now is to listen to your song until the end at least once before using them in auto mode.
My question is will analyzing the songs accomplish this or do I really have to play each song?
If I need to play each song, how do I accomplish this efficiently? Can I load all the song in on the playlist, set AutoMix Start:Begining, AutoMix End:End and AutoMix Lenght:No Mix? If I play them all once that way before my party will I be ok?
Thanks.
Thanks.
geposted Fri 26 Sep 03 @ 7:45 pm
