Has any one any experience using two of the same cards in dual sound card to mixer mode?
I'm currently using an Audigy and a SB 5.1 card, but as you know, Audigy skips every now and then, and the 5.1 isn't really up to the job sound quality wise.
I talked to creative support and they ran a mile when I said I wanted to use two cards, any help would be appreiciated
Alex Davison
Alex Davison
geposted Wed 22 Oct 03 @ 2:10 pm
          It seems to make troubles to have 2 sames soundcards.
I didn't test it but you should found someone to lend anothers card to test before buy it.
If anyone can say something more ...
geposted Wed 22 Oct 03 @ 6:50 pm
          there should be np proble .. those test are post at the web page .. soryy not give you a direct link .. but ..i know is up there,,,, and it should work
    geposted Sat 01 Nov 03 @ 6:56 am
