What are the features before i purchase atomix, =)
Iknow that u can use your headfones and mix into seperate tracks, anything else that the full version has more then demo version... need to know b4 i purchase the full version.... thx
geposted Wed 12 Nov 03 @ 2:05 am
also, can u set a loop to one part lets say its like 20 seconds long, and press loop again, and it'll loop inside the 20 seconds, cause i know u can do that with Traktor dj mixer...
geposted Wed 12 Nov 03 @ 2:06 am
The difference between Atomixmp3 demo and the full version are:
In full version, you can use headphone for preview, a mix table with 2 output from Atomix, you can use one or 2 sound cards and you have no cut after 15 min.
For the loop, it’s not possible, the maximum for loop is 8, but it’s possible with Virtual DJ
Coyote
Coyote
geposted Wed 12 Nov 03 @ 2:30 am
i am going to go on a limb here...i think that there is some loop effects around that will allow 16 and 32 beat loops...i`ll have to check into that but i think its on the effects page here@atomix
geposted Wed 12 Nov 03 @ 5:13 pm
yes.....i was right.....there is a looper that allows you to adjust the length of the loop right up to 32 beats...lol.....wheres the 64 beat looper......lol
geposted Wed 12 Nov 03 @ 5:19 pm
