I am new to this and I want to use the program to make cds for a wedding coming up. Is there a beginners guide or something I can find?
Thank you
Thank you
geposted Sat 29 Nov 03 @ 9:46 pm
you can try these 2 links:-
http://www.atomixmp3.com/forum/display.html?topic=11677
http://www.atomixmp3.com/support/manual/
geposted Sun 30 Nov 03 @ 12:18 am
one question.......why is this manual not put on-line complete in a pdf format for quick download?...this would free up some space on the web site as well as make it easier for the beginners...i for one would LOVE to have this manual in hard copy for quick reference and if it is in a pdf format it can be taken to a copy/print shop and printed out....
well.........how about it teamers?...would take about an hrs work to do...but it has to be done by someone with COMPLETE access to the on-line files..
geposted Tue 02 Dec 03 @ 10:01 am
Try downloading Virtual DJ. It has a good beat matching function. But if you prefer AtomixMP3, then keep on using it and after a while you'll get used to it like what I did.
geposted Sat 06 Dec 03 @ 7:55 pm
