can you tell me the dif between ...and why there is an installer ...what are the changes?? there is no readme file
geposted Tue 01 Jul 03 @ 7:00 am
Guy, explain a little better please
difference between... : between what ?
and why wrote new database if your question is an other ?
geposted Tue 01 Jul 03 @ 7:45 am
I thin you are asking why is there a need for a converter of the internal database ? Well VDJ uses newer technology to scan files but luckily Yan has come up with a converter so you don't loose your database from Atomix.
geposted Tue 01 Jul 03 @ 8:03 am
thats nice ..thanks to Yan
nice
nice
geposted Tue 01 Jul 03 @ 8:11 am
Can someone help me with this converter? I have thousands of songs that I need to convert from Atomix to VDJ.
Thanks
Zayne
Thanks
Zayne
geposted Mon 01 Dec 03 @ 10:16 pm
there isnt an exact convertor that'll copy everything!
but there is one that will copy bpms
geposted Tue 02 Dec 03 @ 1:22 am
which can be found here:-
https://virtualdj.com/forum/display.html?topic=395
geposted Tue 02 Dec 03 @ 1:24 am
