I've been trialing Atomix now for a few weeks now and are ready to buy it. Please can anyone tell me if its possible to download the full version to my home machine and then install it onto my djing pc. This might be an obvious NO! Anyone!!!
Otherwise, can I send off for it and buy the disk.
Thanks
Thanks
geposted Mon 12 Jan 04 @ 12:15 pm
Once you download the install file, you can either transfer it to your laptop via a network connection, or if that's not possible, you can always put the install file on a CD. It's OK to put it on more than 1 computer, as long as it's for your own personal use only.
Atomixmp3 is only available through internet order, it doesn't come on a CD.
geposted Mon 12 Jan 04 @ 2:33 pm
thanks...............which do i buy....atomix or virtual dj.......are you guys of the same group?
geposted Mon 12 Jan 04 @ 10:17 pm
the V-dj is more of a proffessional verison the the two programs.
geposted Tue 13 Jan 04 @ 5:09 pm
If you have a strong/fast enough computer, with enough RAM, I'd recommend VirtualDJ.
geposted Wed 14 Jan 04 @ 12:57 am
But to me, VIRTUAL DJ is a bit tooooo easy! I mean, i'm looking for something where i can set my own BPM & match my own beats. Do you think thats possible?
DJ BILLY
DJ BILLY
geposted Sat 17 Jan 04 @ 3:11 pm
