I've noticed on professional mixtapes all of their songs mix together yet you can still go staight to any given track w/o listening to the wholle cd like a regular tape. How do i do this using your software.
geposted Sat 24 Jan 04 @ 10:08 pm
I've not found a way to do this in Atomix, apart from using lightning fast fingers on the Record tab.
I've been using CoolEdit to chop up and index mixes - you'll need a lot of memory if your mixes are long.
If you've got a Creative soundcard you should also have the .wav editor they bundle with the software
geposted Mon 26 Jan 04 @ 2:47 pm
I believe you can set cue points using your burning software.
geposted Tue 27 Jan 04 @ 12:44 am
