Forum: Old versions
Topic: Firmware update for DJ Console
Hercules have just updated the firmware on the console and have an update on their website. They say it is to:-
- Improve Pitch slider sensitivity
- Improve controller latency
Hopefully this will not cause any more problems than it fixes.
geposted Thu 04 Mar 04 @ 10:46 am
I wasn't able to download it. There was a problem with the site.
I love it when a plan comes together.
www.idgaf.com
Do you just run the file to update the firmware?
Yes.
Make sure your console is connected to your computer, download the .exe and run it.
When it's finished updated you'll be told to disconnect and then re-connect your console to the computer.
Just updated to thelatest firmware and no VirtualDJ errors when loading eveytime. Anyone else have this problem or know of a fix?
I had the same, I rebooted and it worked fine.
YAY !
Me very happy :)
