I was wondering if any of you had any luck using a touchscreen mouse (such as the Magic Touch: http://www.magictouch.com/addon.html) instead of an external mixer. I don't know if the response would be as sensitive or exact, but the loop and effect buttons would be much more conveniently located. Has anyone tried this?
geposted Thu 15 Apr 04 @ 6:51 am
I use a LCD touch screen monitor and it works well for the effects ... but I combine using a external mixer for everything else... and I found that using a mouse for moving files to the decks is easier. The add on touch screen in your link will do the same thing and work for what you want.
geposted Fri 16 Apr 04 @ 10:42 pm
Hey YA!!
Guys I need some help wat the **** should I do to creat a skin?
geposted Sun 25 Apr 04 @ 7:36 pm
Well Master Mania....if you want to make skins go here
http://www.atomixmp3.com/support/developers/skinref.html
you will find all you need to know there....my thought on this is the guys who are creating skins now are tops......so i won't even try to learn how to make one.....however i look forward to trying out one of your creations....good luck
geposted Wed 28 Apr 04 @ 9:16 am
