Forum: Old versions
Topic: Can I stream?
Can I live stream using atomix and realproducer?
I have a 2 soundcard set up but find it hard to configure the line in and also to have a seperate que up output.
Any help please?
geposted Mon 19 Apr 04 @ 12:50 pm
Hi
You can't use 2 soundcards set up with the demo version, so, if you have a full version, please update your profile by entering your serial number in the appropriate place.
Thanks
I have the full version but couldnt be bothered to enter my serial number but its ok ive sussed it
