:QUOTE: The minimum requirement to run Virtual DJ is:
PIII 850 MhZ computer
800x600 SVGA video
DirectX compatible soundcard
128 MB RAM
20 MB free on the hard-drive :END QUOTE:
the only thing i have is an 80 gig hard drive...guess i am going to have to get a new computer :((.....i was looking forward to trying this out...oh well......one day i will
800x600 SVGA video
128 MB RAM
geposted Tue 01 Jul 03 @ 9:21 am
You have an 80 gig hard drive... Well, you only require 20 gigs free.
Also, you don't run out and buy a whole new computer just because you need some hard drive space :-)
geposted Tue 01 Jul 03 @ 10:51 am
but i don`t have the other min. requirements...lol....and this computer is 4 years old...time to get a new one anyways...heh he heh
geposted Tue 01 Jul 03 @ 12:26 pm
VirtualDJ runs on my PIII 677Mhz with 32Mb graphic and 198Mb ram without any problems (but i don't use the v-scratch, broadcast or recording)
CU
CU
geposted Tue 01 Jul 03 @ 8:39 pm
well.....i have a pentium 11 450...64 megs of ram........not enough i think.....but i`ll try the demo
geposted Wed 02 Jul 03 @ 1:34 pm
i have an
athelon 1 gig, with 256mb ram
and a 64 meg gfx card and win2k.
virtual dj is not running well at all.
it is ok in limited skin mode, but when
i put it into full skin mode, with all
the options, it plays but is very jittery
with the music when two tracks are
playing at once.
im displaying it at 1024*768.
is there any fixes for this, as my computer
meets the necessary requirements listed,
yet this by no way possible to use as a full
registered user.
any ideas, or is a refund in order?
-andrew
playing at once.
registered user.
-andrew
geposted Wed 02 Jul 03 @ 2:29 pm
Andrew,
Please be sure you have all the latest updates for your sound and video card. Also disable all antivirus software and any other programs that you have running. I am running VDJ on a Atlon 850mhz with 512 ram witn no troubles. I believe you have the requirements maybe just not all the updates.
DJ Homeboy
DJ Homeboy
geposted Wed 02 Jul 03 @ 11:14 pm
RAM is cheap!! add another 256 of ram, I'll bet your problems will be solved...
geposted Wed 02 Jul 03 @ 11:21 pm
